RV-Ron
Mar 20, 2014Explorer
Coleman Presidential furnace 4324-729 disassembly
I am looking for, at minimum, an exploded parts view of this aged furnace. A service manual would be great, but I'm not holding my breath...
I have initially diagnosed the pilot light problem as a thermocouple, which seems near impossible to disconnect from the gas control valve.
It appears that (after replacing the main propane tank shut-off valve) the internal components, gas control valve etc., should be able to 'slide out' forward after disconnecting the gas supply line.
It 'appears' that this is the proper method for servicing this unit; but I'm stumped as to what I'm missing in trying to do so.
I have searched this site, as well as other locations around the net to no avail. Any insights would be GREATLY appreciated.
The furnace is circa 1981, installed in a Winnebago Brave.
