StephJohn2010
Dec 02, 2013Explorer
Confusing Electrical Problem with my TRC Surge Guard
I have a Surge Guard 40250 with an automatic transfer switch. I'm currently hooked up to shore power at a big rv park.
My problem over the past couple days is my surge protector keeps shutting down the electric to my rig (about 7 times in the last 2 days). Here is what I've observed from the digital readout remote installed with the surge guard: L1 voltage would be 132 and L2 voltage would be 127 with only a 1 or 2 amp load on each line. Then I'd turn the electric water heater on (10amp load). L1 voltage would go to 133 and L2 voltage would be 125. I would when also add another 10 amp load with the electric heat pump. Both the electric water heater and electric heat pump are on L2. After about 15 seconds, my surge protector disconnects the shore power from my rig because of high voltage in L1.
I plan on contacting the office of the rv park tomorrow, but wanted to get people's opinion on this forum. What's going on here? Thanks in advance.
