facalton's avatar
facalton
Converter not charging batteries
My converter is not charging the batteries. I have cleaned battery posts and verified that all breakers are OK. What should I look for? Do I need to pull the converter and check to see if anything has come loose?
  • First thing is diconnect batt and on shore power see if lights and fans work.
  • Have you disconnected the batteries at all lately? If so it's possible you hooked up a battery incorrectly and blew a reverse polarity fuse.
    In your power center pull and look at any 30 or 40 amp fuses as they are usually a reverse polarity fuse. Any that are blown and you either have or had a battery hooked up wrong.
  • wa8yxm's avatar
    wa8yxm
    Ok first step (YOU WILL NEED A VOLTMETER digital preferred)
    Measure converter output at the converter (If it's part of the power distribution panel look for the 30 amp fuses.. Should see about 13.6 to 14.6 on BOTH sides of the fuse with the fuse in place (probe the small holes on either end of the fuse top to a known ground) if it's a stand along measure at the output terminals.
    IF you find a lower voltage.. Bad converter (more on that) is likely.
    Then measure at the battery.. Should be about the same (May be a bit lower) if you find 12.6 or less at the battery look for the battery disconnect and measure both sides of it. This may be a solenoid (Big Relay like device, looks a bit like a ford starter solenoid) or a switch.
    Also any circuit breakers in the main battery line.
    NOTE: if you find different voltages on the two ends of the 30 amp fuses.
    UNPLUG wait 5 minutes. replace the 30 amp fuses and plug back in.
    IF converter (Oh stand alone converters will have 30 amp fuses as well) tests as bad... Progressive Dynamics
    Stand along go with 9200 (try to match the last two digits to what you have now. IE you have an xx60 get a 9260)
    Part of the power distribution panel. 4600 (Same last two)
  • Have you physically checked the output of the converter with a VOM? And checked for blown fuses, and checked the input voltage?
  • Without more information, like make and model of converter, make and model of rig.
    Start by checking fuses in the 12 volt DC distribution panel.
  • Often it helps to post your equipment, model numbers etc.
    Load test the batteries, check for AC to the charger, buy a voltmeter and post battery voltage with/without AC. Check breakers, fuses, wiring etc.
