DustyRooster's avatar
DustyRooster
Disable Dometic Heat pump on AC unit? (for dry camping)
Good morning, All!
I have a question I am hoping one of you can help with.
Purchased a 2015 coachmen class C and unknowingly it has a heat pump integrated with the AC.
This would be good news, if I used campgrounds often.
I boondock quite often, and when the heating circuit sees AC the heatpump wants to run in conjunction with the furnace, as those with heat pumps already know. This is not a good situation when on batteries. The 12v furnace is easily useable all night vs a heat pump firing up and taking the battery down to almost nothing its first run.
How do I disable that "feature" to stop the heat pump from firing when I only want the furnace? Is there a way?
I tried to shut off the breaker of the AC. That does allow the furnace to work without the heatpump, but I have to CRANK UP the thermostat in order to get the propane furnace to fire, and It does not have the 1/2 degree or 1 degree to kick on the furnace alone. So it's like the system "needs" the heat pump for operation.
Any way around this?
Appreciate any input!
Having RV issues? Connect with others who have been in your shoes.24,371 PostsLatest Activity: Mar 20, 2026
