- LynnandCarolExplorerGot it thanks! The plastic was brittle, broke two more blades getting it out. We see if they make a metal one!!
- Chris_BryantExplorer IIShould be fairly easy- it may be easier to remove some of the sheet metal, but IIRC you can remove it without disassembly- it's just a tight squeeze getting it out.
For the sheet metal it should just be a bunch of sheet metal screws needing a 5/16 nut driver to remove, for the fan just loosen the clamp and slide it off. - Mandalay_ParrExplorerDon't know about yours in particular but many are held on with a set screw.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
