Leatherneck2093
Jul 24, 2020Explorer
Dometic 4 door 12cuft fridge not getting below 40 degrees
We bought very rarely used like new 2019 Grand Design Reflection 28bh. We are on our maiden voyage check out trip. The dometic 4 door 12 cuft fridge, which is in a slide out, is set to 5 and doesn’t want to cool below 40. The freezer stays between 12-17 degrees. I can hear fans on the back of the fridge running from time to time. I don't see the thermistor clip on the inside fins that I can adjust. Daytime temps are running 90-96. We are in a nicely shaded spot so the fridge doesn’t see direct sun.
I have noticed that the cabinet around the fridge is really warm. That tells me that its not insulated and a lot of the heat from the cooling unit coil is filling that void. Is insulating that void around he body of the fridge something that would adversely affect its operation or would that be a good thing to do?
There is a baffle in the top vent that covers 2/3’s of the vent cover. That doesn’t make a lot of since to me either.
I tried searching for this but wasn’t successful.
Any help or direction to a previous thread would be greatly appreciated.
