hydrocynus
Feb 27, 2017Explorer
Dometic fridge works only on LP for a couple of months
Hello all.,
I have a DM2852RBX (dometic brand) for a couple of years and it started acting about two years ago by cooling with LP only. It is a two way fridge that works on AC and LP only. I took the manual and tested all the components. The heating AC component reads 44 ohms which is spot on, the board is under voltage and receives the adequate DC and AC. Both fuses are good. When I remove the thermistor to test the board the fridge still works on LP only. I cannot get it to switch to AC. The AC heating element does not get any current/voltage.
Based on my testings, I ordered a refurbished board from Amazon (Dometic (3316348.900)) but after installation, the fridge still switches to LP (although it is on AUTO).
So, I suspect my heating element although the resistance tests correctly. Any idea before I order a new heating element? The reason I am doing all the diagnostics myself (the unit still under warranty) is that the cost of a visit by a specialist is more than just replace the parts (if I had an ammonia leak, that would be different).
Thanks for helping.
Serge
Thanks for helping.
Serge
