kingsransom's avatar
kingsransom
DOMETIC REFRIGERATOR RM1350 NOT WORKING ON ELECTRIC POWER
I have a 2012 Dometic refrigerator that is only working on propane. We had this issue once before (a year ago), and only had to replace the fuse in the outside compartment of the frig. We got another fuse, the frig started working on shore power, then within 10-15 minutes it changed to propane again. We had someone come to check it, but he wants to just replace everything not knowing what is really wrong with it, and charge us approx $800. Our panel inside the frig has the auto light on, and the LA light on. Any ideas what may be wrong?
  • I would also look closely at the fuse holder for the fuse you replaced- if they get loose, the fuse can actually melt and open (but look good), plus the holder could just be broken.
  • The unit is not seeing 120 volts AC. Have you checked the receptacle with a known good appliance such as light, hair dryer?
  • No, no error codes on refrig. The dot is lit for auto and lp, along with the temp. Is there any way to know if it is the circuit, or the heaters, or could it have anything to do with the 12 volt portion? IE: how do I determine the part that has the problem without having to replace the circuit board and the 2 heaters (and hope it was one of them). KO, I see that you are in Tampa, do you recommend any dealer there for repairs? I need someone to work with my warranty company. Thanks for your help.
  • Are you buy chance getting any error codes on the refer?
  • Open the outside access, on the right side is a square or round vertical assembly. On the bottom is where the LP flame is located. About 12-15 inches up there should be a pair of wires coming out that go to the circuit board. These are the wires to the element.
    Use a known good 120 volt device such as a light or drill to test outlet.
  • 1) Verify 120 volts is present in receptacle.
    Locate the two small wires going to the stack from the circuit board.
    2) Use a volt meter to check to see if there is 120 volts coming out of the circuit board.
    No, voltage, bad circuit board.
    Voltage, disconnect power to the refer, disconnect the wires going to the stack. Use Ohm meter to check for continuity. No, continuity, bad element.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
