ncrowley
May 12, 2017Explorer II
Dometic Sealand Toilet Leak
My Dometic Sealand toilet leaks when the lever is raised to fill the bowl. In the picture, there is a black seal in the middle with a brass pipe above it. I removed the plastic cover for the arm that fills and empties the bowl to see this. Water gathers above the black seal when I lift the lever to fill the bowl and then will spill over.
Can I repair this? What parts would I need and how would I replace them?
Thanks.
Thanks.
