unsavory
Jan 29, 2020Explorer
Dual batteries, DC to DC chargers, isolators, AGM... HELP!
Apologies for the long post, but I've been super impressed with the technical knowledge I've seen in on this forum and am hoping someone might be able to help.
I own a 2019 Jeep Wrangler, and have installed a Genesis dual battery system into it for running various accessories. The system is basically two 12v Odyssey dual purpose AGM batteries, with a smart isolator between them, that will automatically disconnect the accessory battery from the starting battery when a certain voltage is reached to avoid draining the starter battery, and then reconnect them when the vehicle is running for charging.
The problem I am having, is that I am not able to get these Odyssey batteries to charge properly in the Jeep Wrangler, because it has a very funky "smart charging system", that varies the charging voltage as you are driving to "save gas mileage". The voltage will fluctuate between 12.7v and 14.7v depending on the battery voltage and accelerator pedal.
Apparently Odyssey batteries only like to be charged at 14.7 volts for bulk charging, and 13.7 for float charging to top them off.
So now I'm looking into DC to DC chargers in order to get my charging voltages up to the correct level. Has anyone had any luck installing a DC to DC charger along side an already existing dual battery system that has a smart isolator built into it?
All of the DC to DC chargers seem to want the starter battery separated from the accessory battery, as they already have an isolator built in.
The other option I am exploring, is just disabling the smart charging in the Jeep by disconnecting the Intelligent Battery Sensor. But this causes the alternator to put out a constant 14.5v, and I'm worried this will actually OVERCHARGE my batteries... but I'm not sure?
Any other creative ideas I can try?
