Campin_LI's avatar
Campin_LI
Electric Cable
I am planning to run 10-2 UF-B cable about 100 ft so that I can plug my travel trailer in while at home. The trailer requires 30 amps.
I also want to add a regular 15 (or 20) amp outlet so that I could plug other things in when necessary. Can I pigtail this outlet off the 10 gauge 30 amp cable? Should I use 8 gauge wire for this? The other alternative coming to mind is running 10-3 cable instead to keep the outlets separate.
Thanks in advance for ideas/suggestions or things you did.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
