n7bsn
Feb 20, 2014Explorer
emm... not heat
The standard Suburban furnace that well, almost everyone has.
Worked fine all week, we stopped for lunch on the way home, since it was cold I went to turn the heat on for the critters, only no joy.
So I waited until we got home. When I switch the thermostat to "heat" I can hear a relay fire in the thermostat, followed by the click of a relay/solenoid in the furnace. But the fan does not come on.
When I switch the thermostat off, both units "click" again.
No I'm guessing some kind of failure in the furnace control board, but...other possibilities?
---edit---
Propane is fine, the stove and refer run perfect
(I recall the fan runs fine with no propane, just no heat)
---edit---
