โJul-20-2018 07:51 PM
โJul-22-2018 11:39 AM
โJul-21-2018 04:26 PM
โJul-21-2018 03:43 PM
โJul-21-2018 01:08 PM
Old-Biscuit wrote:ScottG wrote:
Good point about the different temp set point OB.
I know your familiar with these things; what temp setting would you use for the roof fan?
They say it's preset to #5 for the sensor to be on the second to bottom tube. Good nuff?
#5 is same as Norcold OEM.....On/130*F - Off/115*F
I would test it at the same setting....checking to see IF the ARP controlled fan comes ON at same time as Norcold OEM fan
Then change ARP Fan setting to coincide with Norcold OEM
Suspect you will end up on #4/#3 setting so both fans run together
โJul-21-2018 09:18 AM
โJul-21-2018 08:55 AM
joelc wrote:
I have a 10 cu. single door Norcold. I installed a small muffin fan to the lower area that I turn on in hot weather. I have it raised slightly so air can get uner it and it blows upward. The air flow helps the fridge quite a bit. I hook the 12V to one of the wires on the fridge. I just wish I had a thermal switch. But it works great. You will be very happy with your results. The idea is to cool the fins on the top and to increase air flow.
โJul-21-2018 08:35 AM
โJul-21-2018 08:29 AM
โJul-20-2018 09:33 PM
