clinedinstjt's avatar
clinedinstjt
fuel filter
Where is the fuel filter located on a 10000 onan diesel generator?
  • Onan 10k Parts
    Fuel Filter NAPA 3063
    Oil Filter
    NAPA 1307
    Air Filter NAPA 6449
    Fuel Pump Amazon Airtex E11020
    Cummins Onan # 187-1289 glow plugs are $49 each, and NGK # 5392 Y720U are $10 each from Rock Auto… you need three.
    Fuel filter is locate din the side access door down low and to the right, silver in color. Two 10mm bolts on the outside of case will release the filter bracket and you can lift the whole assembly out and change the filter. Pay attention to orientation of the two fuel lines and the whole thing pops right back in...misalign the connections and you will be using wordy dords!! Easy after the first time.
    Part # above will save you a bunch of $$
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 27, 2025
