โNov-22-2014 08:04 PM
โNov-23-2014 01:16 PM
Snowman9000 wrote:
Been reading archives, but not clear whether a converter's output should be fused. (This is not about the reverse polarity fuses found on all converters.)
โNov-23-2014 12:46 PM
โNov-23-2014 12:30 PM
โNov-23-2014 12:27 PM
ScottG wrote:
The reverse polarity fuses are the fuse for the converters output.
Adding another would be redundant.
As Roy wrote, it needs a fuse or breaker close to the battery for protection for the wires and battery.
โNov-23-2014 08:14 AM
โNov-23-2014 06:08 AM
โNov-23-2014 05:41 AM
โNov-23-2014 05:37 AM
โNov-23-2014 04:16 AM
KD4UPL wrote:
Anything hooked to the battery will need a fuse. The battery is capable of delivering hundreds of amps during a short circuit. What if your converter shorts internally? How will it do with 100, 200, or more amps flowing thru the short before your main battery fuse blows?
โNov-23-2014 04:15 AM
newman fulltimer wrote:
the converter wires directly into the fuse panel
โNov-23-2014 04:10 AM
โNov-22-2014 08:20 PM
