icanon wrote:
Reason why I stated portable is that folk with 'hardwired' have no choice or bypass the system.
Well that doesn't have to be the case ... regardless of brand all one has to do when wiring in a hard wire surge protector is to add a set of 30 amp connectors to the incoming main service line and a couple of matching 30 amp pigtails to the surge protector itself so it can be removed anytime in seconds, just as I've done.
Progressive Industries EMS-HW30C Surge Protector - Removable InstallationSecondly, it should be noted that switching the EMS to "bypass" is a bit of a misnomer as that doesn't actually remove it entirely from the system as the surge protection part of the system always remains active. The only way to truly "bypass" the EMS is to remove it from the system, either physically or by externally switching it out of the system - for simplicity I've chosen the former as I
will be doing this whenever I may be plugging into either my 1000 watt PSW inverter or Honda EU2000i inverter genset.
One might wonder why I chose the hard wire EMS-HW30C over your portable EMS-PT30C which I could have also installed inside the trailer by adding 30 amp connectors to the incoming main service cable ..... :h
First, and most importantly, my hard wire model is field serviceable so should it ever fail I can repair it myself by simply dropping in a new circuit board that Progressive will supply under terms of the lifetime warranty. OTOH your portable version is factory sealed and must be returned to Progressive for repair ... not as much of an issue for anyone in the US where Progressive Industries is located but much more of a hassle for those of us here Canada as it means dealing with customs.
Secondly, I can adjust the hard wire version's delay time to either 15 secs or 136 secs ... for now I've left it at 15 sec for the convenience but next season when we begin using our Dometic Brisk II A/C which doesn't have built in compressor delay I'll switch the EMS's delay to 136 secs. Your portable unit is fixed at 136 secs.
Third, now that I have it installed I really like the informative
Monitor Display that scrolls through Error, Previous Error, Incoming Source Voltage, Current Draw, and Frequency. Your portable version does as well but because it would normally be sitting at the campsite post I'd find that much less useful and if I instead installed it inside the camper as I did with my previous portable TRC unit I wouldn't be able to see the display anyway.
FWIW, first time out last weekend with my new EMS we lost power in the campground several times so not only did the EMS disconnect the trailer from the failing incoming source power the display, by showing a previous error code, told me that in the course of losing that power the source also lost ground. :E Gotta say, I'm really impressed with this Progressive Industries EMS-HW30C. :B
