NoJive's avatar
NoJive
Generator not putting out enough wattage...I think
Newbie here, but I am posting because I cannot find my exact problem anywhere else. All I am finding is low voltage or no voltage issues.
I have a Harbor Freight 4000 watt (3200 watt running) generator that we use for camping, and power outage purposes. I've had it for around three years, and it has given me no problems except for noise (it is loud!). Anyways, we are camping on our river property this month, and I noticed the generator running faster than it normally does. We use it to run the A/C as needed, and it seems to idle down once the compressor kicks in, and then speeds up once that kicks off. That seems like the opposite of what it used to do. I also found out that it now no longer runs the microwave, which it used to do fine. Now, the generator bogs way down, and the microwave barely runs.
I did call Harbor Freight, and they seemed to think the voltage regulator was going bad, so I bought a new one, but that didn't seem to help any. I'm getting 116v on the outlets, so it doesn't seem to be a voltage issue.
Is there anything else I can check?
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 07, 2025
