RedRocket204
Aug 30, 2017Explorer
Grape 40 Amp PWM Charge Controller versus ?
I often see recommendations for the Grape Solar GS-PWM-40BT 40 Amp PWM Solar Charge Controller. The Grape controller was recommended as a potential replacement for my Renogy 30A PWM LCD Controller and I'm not discounting the advice. However, I'd like to know a bit more specifics behind the recommendations.
I moved forward with my installation of a Renogy 200W kit, which as mentioned included the Renogy PWM 30A LCD Controller. It is the one with an identical form factor of the Grape GS-PWM-40BT. Even though it has the same form factor, I feel confident that the internals are different. Grape having 40A capability versus the Renogy at 30A. Grape also having the remote BT connection capability where the Renogy does not. Even stranger is that both Controllers use the exact same manual layout minus name changes... at least that is what I recall from when I looked through both manuals 4 weeks ago.
I'm currently running (2) 100W Renogy panels along with the Renogy 30A PWM LCD Controller with (2) 12V Group 24 flooded batteries. I recently took a 5 day boondocking trip, no shade cast on the panels, and the batteries seemed very quick to recharge. Although I did not have extensive energy demands, at least I believe, on the batteries. 2 people using ~ 4 LED lights for a few hours, Fridge running on PP, PP detector, Direct wired USB ports for charging 2 cell phones, Water pump for 2 showers daily, and the furnace which did get used as mornings were 29f at 9,500 feet elevation.
Back to the recommendation for Grape aside from the 10A delta and BT capability. What is the reason for the Grape recommendation? Is it related to efficiency, longevity, better internal build quality for charging, support?
Again, I'm not discounting the advice, just looking for answers as to specifics on why the recommendation. Thank you in advance for any responses.
