BuffaloIndian's avatar
Apr 11, 2014
Have You Installed a Residential Fridge and Inverter in TT?
I have decided replace my failed Dometic RM2652 RV fridge with a residential unit. I have found and ordered a replacement (Summit F882W) that fits my space (after removing an upper shelf); have removed the old unit, capped off the gas supply, and cleaned up the space. Now I am just awaiting delivery. My rig is a 2007 Sunset Creek with two slides.
Since this is a unit that we set up and leave in one spot for two or three months at a time, and never dry-camp, having an inverter/battery set-up is not essential. I am usually at my destination within 4 hours or 5 max. However, it would be nice to have the unit cooling while we travel and have the luxury of making stop-overs at the rest area.
I am looking at a Tripp-Lite MRV2012UL PowerVerter to replace my stock converter (2000 watts continuous inverter power), but I am not sure how exactly to wire it. Also, how many batteries do I need? Do I have to go with a 6-volt bank, or can I function with two 12-volt batteries?
Has any of you modified a travel trailer for this kind of set-up? Thanks
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
