DinTulsa's avatar
DinTulsa
Help me build a 30 to 50 amp extension cord...
Just installed a 30 amp rv outlet at my house, the outlet is 60ft from my panel and is powered by 8/2 wire. I couldn't run a 50 amp didn't have the space.
My plan was to buy a 50ft 30 amp cord and use my adaptor to hook it to my 50 amp rv cord. But I got to thinking that the 60ft from the panel, then a 50ft extension cord tied to my 30 ft rv cord might be a little long considering voltage drop. That puts my total run at 140ft to power the rv. The only thing this plug will run are lights, fridge and 1 AC while it's parked getting ready to travel. We will not be staying for extended periods of time or running microwaves, water heaters or anything else because we can't keep it parked for longer than 48 hours.
My question is, if I wanted to build a 50ft 8/2 extension cord with a 30 amp male and 50 amp female connection, how would I wired the 50 amp female side to ensure I power both legs.
Thanks
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
