- Open neutral!
Unplug immediately and get some qualified electrical help.
Damage may have already occurred. - opnspacesNavigator IIIf he's using an adapter to go from 30A to 15A the adapter might be bad. Otherwise I second the professional.
- wolfe10ExplorerIs this at a camp ground or at home-wired outlet.
50 amp coach or 30?
Something IS mis-wired, and DANGEROUSLY SO.
Disconnect immediately and find and fix the cause before plugging back in. - wolfe10Explorer
No, both 15 and 30 amp have ONLY ONE HOT. No way to get 220 VAC with only one hot. - john_betExplorer II
Buddhacamp wrote:
Where is this GFI located? my guess would be a bad meter.
My buddy has a 2003 Holiday Rambler Vacationer 33ft. He has no interior lights or outlets working. With shore power plugged in he measures 220V at the gfi outlet? Any ideas? Thanks! - Try disconnecting from shore power. Start genset and check voltages.
It may be too late if it was connected up to system with open neutral or incorrectly wired shore connection. - BobboExplorer II
With the exception of an electrical fire, this is as bad as it gets. Many expensive appliances are probably junk now. Unplug and get a professional to track down the problem. - tenbearExplorerWhat is the voltage where the RV is plugged in? Some people have had electricians wire up a 30 amp receptacle and the electrician assumed the receptacle was a 220v receptacle.
- opnspacesNavigator IIAlso seem many posts where someone incorrectly plugs a 30 amp plug into a home electric dryer outlet which is 220v. Where is your friend plugged in?
- BuddhacampExplorerHe is a full timer at a camp ground and plugged into the box 30 amp. He comes home on weekends and had 2 space heaters plugged in. Came back Monday to this situation. Has 220 volts at GFI and microwave plug and microwave is shot. Propane is cheaper than this ;) Thanks for the replies!
