Unicorn1108's avatar
Unicorn1108
House batteries to use with large inverter
We're planning some camping where generator use is restricted, so I want to make sure my batteries will hold up between charges. We'll usually draw less than 25 amps, but I'd like the option of running the microwave with my 2000W inverter, which I expect will draw at least 150A. If not for the microwave, I'd avoid marine batteries or any battery with specs for cranking amps, but is running the microwave similar to starting an engine? Should I get a dual-purpose battery, or just make sure I have enough deep discharge batteries to supply 150A?
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
