mdecorso's avatar
mdecorso
House battery not charging properly. Bypass solenoid?
I am having some difficulty getting my house battery in my 1992 Ford E350 Class C Four Winds to charge properly. I think the solenoid between the engine battery and house battery is failing.
On the engine battery side of the solenoid, with the engine running, I get a 12.7 volt reading with my tester, with the positive tester lead on the solenoid post and negative lead on the engine negative battery post.
On the house battery side of the solenoid, with the negative lead on the engine negative battery post and the positive lead on the post on the house battery side of the solenoid, I get an 11.7 reading.
With my Onan generator running, I get a 13.8 reading at the engine battery and engine battery side of the solenoid, and an 11.8 reading at the house battery side of the solenoid.
Does this mean my solenoid is failing? Both batteries are brand new.
I am in Europe and it may be difficult to find an appropriate soleinod. Can I bypass the solenoid to get my battery to charge until I find the proper replacement part if I need one?
ThaNks.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
