Big_Katuna
Aug 06, 2018Explorer II
Good luck. If you end up replacing them with wet cell, spend up and get a Profill system.
You replace all the caps with their caps plumbed together with tubes to a common point.
You connect a hand bulb to it once a month stick the hose in a gallon of distilled water and it fills all the cells. Their cap prevents over filling.
My 13 year old RV is on its third set of T 105s.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 18, 2025
