KenNTennessee's avatar
Mar 14, 2014
Is it okay to link two batteries of unequal size?
We just bought a new travel trailer and it came with a dealer installed new 24MS battery, which does not have enough capacity for us as we do dry camping up to three days at a time. I am going to install a second battery and would like to get a 27DC battery, but am not sure if there would be problems having two 12V batteries of different capacities hooked in parallel. In theory hooking batteries in parallel, you should be able to add the amp hours together. So if the 24MS has a reserve capacity of 90 and the 27DC has a reserve capacity of 115, then the total reserve capacity would be 205. My question is will there be an issue with charging or will the battery life be affected since they are not the same capacity?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
