profdant139's avatar
profdant139
May 14, 2014
Leave carb drain open on Honda gen in storage?
After I drain the carburetor after using my Honda 2000, should I leave the drain screw open till the next time I use it, or should I close the drain while the generator is in storage? (I run it every month, with a 1500 watt heat gun attached to give it some exercise.)
(I tried to look this up on the archive and could not find an answer.)
Thanks for your advice!
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
