steved28's avatar
steved28
Low pressure propane outlet - useless?
Our new RV has a quick disconnect port for propane accessories. The problem as I see it is, it is after the regulator. I have tried to use it on a couple grills and it seems you cannot put regulated gas into a regulated device.
On my previous RV I installed a "Tee" type connector BEFORE the regulator and used it all the time. It worked well. I just don't see any use for this new propane outlet. Does anyone have devices that actually take a pre-regulated source? I.e., they don't have their own regulator?
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
