BobnMelba's avatar
BobnMelba
lp guage accuracy
I know you can only fill the tank to about 80% but I am wondering if the gauge should read full when it is filled to capacity. Mine only shows about 3/4 full when it is filled. Is this normal?
  • Those gauges are very inaccurate. Once installed, they're never checked again. Fillers aren't allowed to rely on them.
    Lynn
  • Windsor-Monaco wrote:
    Mine does the same, I tried to have a propane place fill it further thinking I was a bit low. It spewed out and the technician stated this tank is FULL. Oh well, I figured the gauges weren't calibrated. It's good to know it's normal for others as well.
    IF this LP filler is in Texas, he should be reported to his boss. You NEVER let a customer dictate how and how much you put into a LP tank. The filler should have known by 1. if the OPD shut it off and 2.if he saw liquid out of the 80% valve. Regardless, you NEVER fill more once it shuts off. Doug
  • Non adjustable LP gauges (remote panel) will usually only show 3/4. Which is NORMAL as they only hold 80%. You want to quibble 5%????:B
    Adjustable Remote panels, you CAN adjust to full or 100%, but it is a false level, as you may run out when it shows 1/4. LP tanks do NOT have any baffles, so when you are moving the Liquid sloshes and if you watch the LP gauge on the remote panel, you will see it hit full and then down. Doug
  • Mine does the same, I tried to have a propane place fill it further thinking I was a bit low. It spewed out and the technician stated this tank is FULL. Oh well, I figured the gauges weren't calibrated. It's good to know it's normal for others as well.
Having RV issues? Connect with others who have been in your shoes.24,209 PostsLatest Activity: Feb 24, 2025
