I have a bad coil 120-105452-6 and have a replacement 120-105752-6 bith made by white rogers and need to know if they are interchangeble. White Rogers says they have no info. Need help.
If there is only one small terminal, it is the power connection. The ground would be through the metal base. Some rigs route the ground through a monitoring system. Verify that the old and new relays are exactly the same configuration.
