Almot's avatar
Almot
Aug 19, 2013
MPPT controller and voltage drop?
Warning - long and technical. Trying to figure out the simplest way to get power from panels to MPPT Rogue, and brains are overheating already.
Didn't want to continue this in my thread on roof top box. Have 2 panels in series, so there are only 2 cables from the array. Narrowed down the options to
1) AWG 10 to combiner box, and AWG 6 to controller. Imp = 8.1A. Voltage drop to controller = 1.25%.
or 2) AWG 10 all the way to controller, no junction box. Imp = 8.1A. Voltage drop 2%.
I cross-checked the results, Southwire and Rogue manual give the same numbers.
Then there is ~1% loss in battery cable at 30A max, but this is a different subject.
Correct me if I'm wrong, voltage drop = AH loss, in case of MPPT. With Option #2 - AWG 10 all the way - I am losing about 0.3 AH daily in winter and 0.6 AH in summer compared to Option #1 (box+ AWG 6), assuming controller works at peak 30A 30% of time in winter and 50% time in summer (fat chance), and the bulk stage goes up to 100% SOC (nonsense, I know).
Sounds like AWG 10 is the ticket. BUT... there is Rogue controller manual, written so well that I'm reading is like a text book, and "the Book" says ;)
The wire used to connect the PV array and battery bank to the MPT-3048 should be of a heavy enough gauge so as not to introduce excessive voltage drops and/or current limitations. At higher currents, light gauge wire may introduce a large voltage drop from the PV array, causing an extreme loss of power and erratic operation of the MPT-3048.
Then they have nice tables (that I used to get my numbers from), so the manual is not just a bla-bla. I am not sure about "erratic operation" though. To me, with MPPT all that matter is "how much AH I can afford to lose", doesn't matter if voltage drop is 2% or 10%, as long as the wire ampacity is sufficient.
Am I missing something?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
