Jun-30-2018 08:38 AM
Jul-01-2018 01:21 PM
Jul-01-2018 11:36 AM
Captain_Happy wrote:
I've got a Suburban water heater with electric element. The water heater has no switch inside the water heater, it's fed from a breaker in the 120 volt electrical panel. The switch on the inside is for the propane only.
No way to find out if the 120 volt in feeding the element is to get yourself an volt/ohm meter and check it for power. Otherwise your just guessing
Jul-01-2018 06:28 AM
Jun-30-2018 03:59 PM
Jun-30-2018 03:36 PM
Jun-30-2018 03:28 PM
Jun-30-2018 02:00 PM
Jun-30-2018 11:08 AM
time2roll wrote:
The water did not self heat.
Jun-30-2018 11:00 AM
Jun-30-2018 09:35 AM
Jun-30-2018 09:18 AM
sch911 wrote:trailerbikecamper wrote:
Both tanks have a local switch at the tank and a primary switch inside the camper. The switch inside was turned off on both campers
I thought the inside switch was for gas and the outside switch was for electric. If the outside switch was left on it would explain this...
Jun-30-2018 09:08 AM
Jun-30-2018 09:05 AM
Jun-30-2018 09:02 AM
