stacaz822's avatar
stacaz822
New RV water pump sputtering air/water at faucets
While draining my clean 50 gallon water tank, I left the water pump running dry for about a half hour, maybe more. When I filled the tank again, it would not suck up any water, indicating that a seal or something in the pump overheated and went bad. Anyway, I replaced the pump with similar model and GPM and pressure. Now it splutters a lot of air with the water. I checked the hose fittings and there is no leak. I took off the pump and ran a hose into a bucket of water for it to suck up, and it works ok with no sputtering. Any ideas? Also, there is a hot water line valve I noticed near a T-fitting to/from the hot water tank. Should this be open or close when using the water pump normally? I tried it both on and off, and still get the air sputtering. Any ideas? Happens with either cold water, hot water, and both. Thanks!
  • azrving wrote:
    You didn't hurt the water pump because they're made to run dry there is nothing in it that is damaged by running without water.
    The old pump does not work anymore. The new one works fine now. Something is wrong with the old one..
  • 2oldman wrote:
    No, leave it up, then read all the responses that didn't bother to read anything past your first post.
    That's right, we specialize in popcorn and beer and won't hesitate to consume a lot of it. :)
  • No, leave it up, then read all the responses that didn't bother to read anything past your first post.
  • You didn't hurt the water pump because they're made to run dry there is nothing in it that is damaged by running without water.
  • Or, leave your post so someone else learns about tightening the bowl...
  • stacaz822 wrote:
    I squeezed that down tighter, and viola, FIXED!
    How do I delete my post??
    You can't delete your post but you can edit it and replace the text with something like "Problem Solved" or "Fixed" or "Ignore" or whatever makes sense to you.
    Contact a moderator and ask to have your post deleted.
  • LOL. After re-reading my own post, I went out and checked the inputs to the pump, and tried tightening them some more, and there is a little bowl strainer on the pump input that was not not all the way tight. I squeezed that down tighter, and viola, FIXED!
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
