โDec-12-2018 01:44 PM
โDec-13-2018 09:53 AM
โDec-13-2018 09:49 AM
DutchmenSport wrote:
Reason I'm so concerned is because I want to get a 50 amp RV outlet installed at home (I have 2 different 30 amps I put in myself), but this 50 amp is just confusing the stuffings out of me. And yes... I do have the phone number for an electrician that can and will do the work... I'm not tackling this one alone! I'm waiting on weather to get a bit warmer, because everything will be done outside where I have a junction splitter box for house and garage.
โDec-13-2018 09:26 AM
โDec-13-2018 09:01 AM
maddog348 wrote:
vermile ~~~ mine is 110 looks nuthin like CG 50A
โDec-13-2018 08:52 AM
healsing wrote:
HI folks,
I'm brand spanking new to RVing.
The trailer I am attempting to make "usable" is a 1988 Companion Classic. Needs work.
My question: when using a 30 amp to 20 amp plug converter does it follow that a portion of the original 220 circuits will not work. Or does the adapter send current to both sides of the 220. I do not have the option of a 30 amp 220 connection. Only 20 amp 110. Some circuits are not working and I want to determine if this is normal or a malfunctioning adapter.
Thanks!!!!!
Rob
โDec-13-2018 08:43 AM
SoundGuy wrote:D.E.Bishop wrote:
I tried reading all the replies and got a horrible headache. I didn't see a real answer to your problem and/or question.
I thought I did ๐ - plug his trailer's 30 amp male plug into a 30 amp female > 15 amp male dogbone and he can power his trailer just fine off a standard 15 amp or 20 amp receptacle. Since a 30 amp feed is a single circuit that means if some 120 vac circuits in the trailer work while others don't then OBVIOUSLY the problem has to be downstream of the power source, the adapter he's using, and the main service cable that's feeding the trailer. First thing to look for are tripped / faulty breakers protecting the circuits that don't work - perhaps it's as simple as a loose wire connection, either at the converter or somewhere in one of the receptacles.
โDec-13-2018 08:06 AM
โDec-13-2018 07:48 AM
โDec-13-2018 07:43 AM
DutchmenSport wrote:Yes, that is exactly what I am saying (providing it is wired correctly).troubledwaters wrote:
Some people should not be giving electrical advice; they don't know what they're talking about. There definitely is 240V available in a 50A RV; it's just not generally used.
So are you saying, I can plug in a 220 volt appliance into a standard 50 amp outlet at a campground and get 220 volts, yet take a "normal" 50 amp plug for an RV and plug into the same outlet and get 50 amp / 110 volt?
โDec-13-2018 07:17 AM
DutchmenSport wrote:Yes that is true. Both are available. Standard NEMA 14-50 power.troubledwaters wrote:
โDec-13-2018 07:11 AM
โDec-13-2018 07:03 AM
โDec-13-2018 05:55 AM
โDec-13-2018 05:45 AM
