Rockinfigs's avatar
Rockinfigs
Norcold 2118 quad door fridge issue
I have a norcold 2118 quad door fridge n after running it for few days off propane with the inside fans in the freezer n fridge running.. The fans inside would stop n I don't hear the propane burning in the back.. Does the inside fans turn off after the fridge reaches a certain temp and turn back on?
  • Rockinfigs wrote:
    So this is what I found in the manual.. I'm assuming the inside fans kick off when it reaches certain temp to defrost the fins and turn back on when done.
    "Although the refrigerator is not frost -free, it is made to limit frost on the cooling fins. At regular intervals, the temperature control system
    automatically melts most of the frost from the cooling fins. The water from the cooling fins drains into a collection cup that is attached to
    the back of the refrigerator. The heat of the cooling system evaporates the water from the collection cup."
    This is true for ALL Norcold refers. What Norcold calls a TCS is just a complete shutdown every 48 to 54 hours of the refer cooling system for about 2 hours. This allows any ice on the evap fins to melt and drain off. For this system to function, the refer must be on Continously. Any time you shut the refer OFF before that 48 to 54 hours, it resets that 48 to 54 hour timer. Now, on your specific model, as Biscuit mentioned, there is not much Norcold has published about the internal fans and their control. But, when I look at the wire schematic, the 2 fans are controlled by the main control board and the ground is common(not switched) and the 12 volt Pos. is ON and OFF thru a relay on the control board. NO tstat is shown for the internal circ fans. That usually means that the fans run all the time WHEN the unit is cooling, they shut OFF when temp is reached and if controlled like the external fans, they shut down anytime the refer doors are open and the interior light comes ON. Close the doors and the fans come back ON. Doug
  • So this is what I found in the manual.. I'm assuming the inside fans kick off when it reaches certain temp to defrost the fins and turns back on when done. I hope
  • Very Little specific info is available for the 2118 model
    Both internal fans (freezer/food compartment) get DC+ thru K6 relay on circuit board
    P4 10 Pin Connector on lower edge of circuit board
    Pin #1 RED DC+ to both fans
    Pin #2 Black DC_- from both fans
    (pins are numbered right to left)
    Doesn't show/mention any controls for fans.....ON when Fridge is ON
    But they could cycle with 'heat source' and or door open/close
    'L' is the 10 pin connector
    Check for DC at #1 & #2 when fans run/don't run
    Propane/Electric Element are on/off based on thermistor temp feedback to thermostat (depending on Temp Setting)
    Thermistor in food compartment---2nd FIN from right measures the FIN temp which is roughly 10*F LOWER then the compartment air temp
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
