โAug-25-2018 09:32 PM
โSep-13-2018 06:51 AM
โSep-12-2018 07:28 PM
โSep-04-2018 09:22 PM
โAug-27-2018 04:57 AM
wnjj wrote:dougrainer wrote:
Do you understand what the "n" REALLY means? Doug
The service manual says exactly this: "No cooling detected by the controls". I abbreviated as "no cooling". My engineering guess is that code is set when nothing else is detected to be wrong but the thermistor is not ever dropping in temperature. It's what you'll get if the cooling unit itself has failed so no amount of flame or AC heater makes the fridge cold.
It's been fine all day so far on propane. At this point I'm going to say the relay has compromised contacts which sometimes work, sometimes stick on and sometimes are resistive enough to not cause an 'H' (open AC heater) but will not cool sufficiently.
โAug-26-2018 06:13 PM
โAug-26-2018 03:04 PM
โAug-26-2018 02:58 PM
โAug-26-2018 12:14 PM
โAug-26-2018 10:52 AM
โAug-26-2018 10:34 AM
โAug-26-2018 09:22 AM
โAug-26-2018 08:37 AM
PaulJ2 wrote:
The way it's acting i would say the AC relay is stuck open. It does sound like a faulty relay. Maybe burned, dirty contacts.
That relay has to switch a 300 watt load on and off.
โAug-26-2018 08:35 AM
ScottG wrote:
Mine seemed to lose cooling for a short period last time we camped but I think maybe it was just going through a defrost cycle. Wonder how long a defrost cycle is?
Maybe that's what yours was doing?
โAug-26-2018 06:41 AM
