Wayne_Dohnal
Aug 20, 2013Explorer
Onan KY broken valve spring
Model 3.6KYFA261120L Spec. L S/N C080167118 (Microquiet 3.6 kW propane)
Genset was running when the valve spring failed so there was a lot of valve-to-piston contact. The valve slides up and down smoothly, there's no sign of a bent stem, and the stem rotates smoothly. It's begging to just have new valve springs popped on and call it a wrap. Questions for those in the know:
1) Is it reasonable to just replace the valve springs and see what happens?
2) Should I at least be pulling the head?
3) The genset is a bit over 2 years past its warranty. In light of this problem being apparently due to defective springs, will Onan possibly cover it past the warranty date?
Thanks!
Thanks!
