jdog
Sep 03, 2014Explorer
Onan propane generator not starting
Onan model # 3.6KYFA2612OL propane generator will not start. Has new spark plug and air filter. Does not seem to have oil pressure sensor. Propane tank is a little under 1/2. Vent. tube is not plugged. I did get it to start by spraying carb cleaner in the air intake with the air filter off. It ran as it should. Kept running until I shut it off. Would not restart without cleaner. What would this indicate? Any help will apprecieated. It is in a 2007 Gulfstream Class C motorhome.
