CarolynandBob's avatar
May 16, 2020
Onan RV QG LP for home back up generator.
I had this gen in my 5th wheel. Last March I pulled it out of the 5th wheel in order to use this as a back up gen for my house. I started it before I pulled it and it worked great. I am in Tennessee and the 5th wheel is in Florida.
Now before I call the electrician to set up the transfer switch on my house I wanted to make sure the generator was operating correctly. I looked up which LP regulator I would need and it said 9-13 WC. I purchased an 11 WC and a new deep cell battery. All it does is turn over. It will not start. I had a remote start switch in the RV. I am not sure if that is disconnected, would the gen not start? If so, where could I get a "loop" or jumper to by pass that feature? I cannot find any info on the web.
I called the nearest Onan service center and they said the would not work on it if it isn't in a RV. They said it was a liability issue, which I disagree, but it is their call.
Thank you in advance.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
