SHRED
Aug 01, 2021Explorer
Parasitic current draw on tow vehicle
My 2002 Honda CRV seems to lose its battery charge if it sits for a couple of days.
The battery has tested good at both NAPA and at Autozone.
I tried testing for draw with my cheap VOM by undoing the ground and running it in series on the 10A meter circuit, but it registered zero which isn't accurate since it draws some power for the clock, etc... I tried turning on the headlights and an interior light, I touched the VOM lead, and nothing. Nothing lit up. Is my VOM bad? It does measure voltage accurately however.
This is frustrating. Looks like I will need to take it in.
Is the allowable amp draw about 0.3 amps?
thanks
thanks
