Pex fittings on our 07 Fleetwood
mchero
I have replaced the shower faucet in our 07 Discovery. I noticed that the PEX fitting are not the standard big box store fittings. Were does one purchase these fittings?
Only PEX I have worked with was at home. I used shark bites, VERY EASY!
The PEX in my fleetwood looks like a plastic sleve is slipped over the outside of the pex, fitting slipped into end & that sleve appears to be holding\clamping te PEX to the fitting.
When replacing the shower faucet I had issues with those little rubber seals that fit inside. I'll post PICS if needed.
Thanks
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
18 REPLIES 18
time2roll
I don't know that fitting but I would cut it off and use sharkbite or gatorbite fittings.
mchero
Here's a PIC of the fittings off my web site;
Robert McHenry
RJsfishin
The only pex fittings I have used,....and seen on RVs is "flair-it", found at any RV supply, and many hardware stores. They are easy to use, can't leak, and are less expensive than other pex fittings. They are also the standard fitting used in most all MFG'd Homes
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
newman_fulltime
next time use flait it fittings
