Ron3rd's avatar
Ron3rd
Jun 24, 2017
Pilot in Atwood stove hard to light
I've got the typical 3 burner Atwood stove, about 3 years old, and the last few times we've had the trailer out, the pilot in the stove has been hard to light, taking forever. I eventually get it lit, but does anyone know why it would be so hard to light recently?
  • wa8yxm's avatar
    wa8yxm
    First it takes a FULL MINUTE for the sensor to register the thing is lit, YOu must hold the dial depressed during that time.
    I usually use a propane torch as a match.
  • Ron3rd's avatar
    Ron3rd
    stickdog wrote:
    Is the thermocouple directly over the pilot flame. I always heat the thermocouple with the flame of the bar-b-que lighter and then turn up the oven to get the gas to the burner. Ours is 13 years old and gets used at least once a week.
    As far as thermocouples go they either work or they don't.
    Not sure, I'll check.
  • Ron3rd's avatar
    Ron3rd
    dougrainer wrote:
    Take the Oven tstat knob off. Insert a small piece of paper inside the "D" shapped hole in the knob. This will cause the knob to NOT fully be inserted into the tstat metal shaft. The usual problem is, when you push the knob IN to light the pilot, you cannot get it fully pushed IN to allow the pilot gas flow. By shimming the knob you get the shaft to fully push IN and the gas flows. VERY common problem and easy fix. Doug
    Good info, thanks. I recall reading a while back a guy did the same thing but he used a small piece of aluminum foil to accomplish the same thing.
  • Is the thermocouple directly over the pilot flame. I always heat the thermocouple with the flame of the bar-b-que lighter and then turn up the oven to get the gas to the burner. Ours is 13 years old and gets used at least once a week.
  • Take the Oven tstat knob off. Insert a small piece of paper inside the "D" shapped hole in the knob. This will cause the knob to NOT fully be inserted into the tstat metal shaft. The usual problem is, when you push the knob IN to light the pilot, you cannot get it fully pushed IN to allow the pilot gas flow. By shimming the knob you get the shaft to fully push IN and the gas flows. VERY common problem and easy fix. Doug
  • Ron3rd's avatar
    Ron3rd
    SoundGuy wrote:
    Being only 3 yrs old I would have thought your 3 stove burners would be spark ignition, with the just the oven below having a pilot. Perhaps you can clarify exactly what it is you're having difficulty with. :h
    Yes, the 3 burners are spark ignition and work fine. The issue is the pilot inside the oven. Sorry, I did not explain clearly.
  • Ron3rd's avatar
    Ron3rd
    darsben1 wrote:
    Do not know why it is hard to light, but if you light off a burner first before trying to light the pilot is that easier?
    Do you mean one of the top burners, or the burner in the stove?
  • Do not know why it is hard to light, but if you light off a burner first before trying to light the pilot is that easier?
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
