dougrainer
Jun 11, 2016Nomad
Usmcsousa wrote:
So quick Update, CG sent an electrician this AM. Of course he suggested underlying issues in my rig at first. Last Night I stayed hooked up to 30amp and all went well. The 50amp breaker was replaced and there was a massive colony of really ugly spiders living behind the breakers. Electrician says the Breaker was "weak" and the furry critters living behind there could have contributed to the strange power issues along with the weak breaker.I am hooked back up to 50amp and so far so good, will see what the night brings. Thank you all very much for your help!!!
The electrician(probably NOT a real electrician) is an idiot. IF you had underlying issues in the RV, you have BREAKERS (15 and 20 amps, maybe a 30 or 2) that would TRIP inside that YOUR breaker box if an appliance/'s were causing an overload. Doug
