HelloImDavid's avatar
HelloImDavid
Power Windows dont work
I took the Battery Terminals off to clean then hooked them back up again. I examined the Circuit Breaker plug in Module for the Power Windows in the Fuse Panel and I get continuity across its two pins. There is no independent fuse that's labeled 'Power Windows' ... just the circuit breaker module
Please help. Is there a procedure to reset the Power Windows ? Thanks.
2008 Coachman Class C. 21 QB model.
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
