gmctoyman
Sep 22, 2013Explorer
Prosine 2.0 Problem
I have my MH wired - shore and generator into a xfer switch, the output from tha sw to the input of my Prosine (built in xfer switch). Output from the Prosine to the breaker box. It all works fine....unless I'm on the generator, and put a heavy (A/C) load on, the generator is a little slow taking the load, the Prosine sees the input voltage dip and drops off the feed. The generator catches up, the voltage stabalizes so the Prosine connected again.
Suggestion ?
Suggestion ?
