dnmccoy's avatar
dnmccoy
Refridgerator issue
We have a Jayco 19XUD and before our last trip I noticed the battery was dead as it had not been plugged in while in storage :(
I brought the camper home and plugged the camper in for a couple days before we left. We precooled the fridge for our trip. I noticed once we hit the road the fridge says its not getting any juice while plugged into my trucks hitch, but will only cool off propane.
Any advice? Would a bad battery not allow it to work off the trucks power?
  • Yeah, I must have been mistaken thinking it was running on ac going down the road. Battery checks out fine :)
  • dnmccoy wrote:
    Well I think we've gotten the problem figured out then...thanks for all the help
    Well..........
    Gonna let us know what you found out?
  • Well I think we've gotten the problem figured out then...thanks for all the help
  • coolmom42 wrote:
    dnmccoy wrote:
    You may be right, but I would've sworn that it would run on ac mode while going down the road. Weve got a couple weeks until our next trip so I'm going to test the battery and get a trickle charger
    It won't be running on AC while going down the road, unless you 1) have a big inverter or 2) have a generator running.
    Or, a VERY long extension cord! :B
    It can't run off AC power unless you are supplying AC power to the RV. That is done by plugging into AC, running your generator, or operating from an inverter.
    A tip;
    Create a profile or signature line so responders know what RV you are asking questions about.
  • You may be right, but I would've sworn that it would run on ac mode while going down the road. Weve got a couple weeks until our next trip so I'm going to test the battery and get a trickle charger
  • It would never work off of trucks power!
    The 12V from truck is just to help maintain the trailer battery voltage. The wire size/length from truck to trailer limits the DC to trailer.
    The trailers battery supplies the trailers DC system when not connected to an AC power source
    If you have a 2-way fridge it will operate on AC using the electric heat element OR off propane (both need 12V DC power for control module --- circuit board)
    If you have a 3-way fridge it will operate on the AC, propane OR using a DC heat element.
    Regardless..........trailer battery has to supply the needed DC voltage. Truck DC just helps maintain trailer battery.
  • That's what it's supposed to do unless it is a 3 way unit(doubtful). They run on either 120v or 12v&LP gas.
