drowe0507's avatar
drowe0507
Refrigerator Control Lock
Last week we had to move our 5th wheel toy hauler due to tropical storm Andrea and it wasn't hooked up to power for a few days. As a result, the propane tank ran out & it was not set to automatically switch to the new tank. Apparently, the refrigerator was trying to ignite for some time with no success and we discovered the refrigerator was not working. Even after AC power was restored, the display screen on our Norcold, model # N821FLT shows a Fault Code "n", which means refrigerator cooling unit has stopped cooling. The manual refers to a 1st time reset by simply turning the refrigerator off then back on. If this does not work, the manual states condition is not owner serviceable, contact dealer. The manual states that the heat sources to the cooling unit are turned off and are locked out by the controls. Is anyone aware of how to "unlock" the heat sources to the cooling unit without having to take it to a service center.
Moved to Tech Issues forum from DIY.
  • This might work for you.
    http://www.aaarv.net/board_reset.htm
  • Try to unplug the refer from the outside and leave it off for a
    minute before plugging it back in. Check your battery with the rv
    disconnected. The converter may not have had time to charge the
    battery after all the restart tries. Light the stove and leave it on for
    a little while to get air out of the propane lines. Finally disconnect the controller board in the outside refer compartment and reconnect.
    Just some things that I would try.
  • My guess would be to contact a qualified service center and see if it is something they can talk you through over the phone.
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
