arthurs_family's avatar
Jul 01, 2016
Replacing my suburban gas and electric 6 gallon water heater
Hi folks! The other night I was sitting in the booth after a shower and all of a sudden my foot started getting wet. Turned on the light and you betcha! My 10 yr old plus camper finally needs a water heater replacement. I have a suburban sw6de gas and electric. Do i replace it with the same one or is there a new water heater to check out. I like the 6 gal it recoups so fast if we have it running gas and electric at the same time
  • The SW6DE has the 120VAC wire hooked directly to the water heater at the junction box. The control switch is located on the front of the water heater.
    The SW6DEL uses a 12 volt relay and a second switch inside the RV to turn on the 120 volt power to the water heater.
    You have three options.
    Buy a SW6DE just like you removed.
    Remove the relay from your new SW6DEL and this will convert the unit to the SW6DE. (This is the easy way to go for your problem) Just remove the relay located in the connection box and then wire the unit just like the one you removed.
    Or, Option 3, add a 12 volt control switch and run a 12 volt wire. This takes some skill and time.
  • Got a new tank and installed it today but now I have a new problem. I ordered a sw6de and they sent me a sw6del. It said it was a same replacement but I have an extra orange wire that runs off the new. Im guessing it's for the A/C side of the heater but my unit only has a single switch to flip inside. Can I wire the red and orange together up to the switch in the coach. The 120v is on the outside of the unit behind the gas tube. Anyone have this issue besides me?
    • Millner's avatar
      Millner
      I am currently doing this exact situation. How did you resolve it
  • Hi yes the tank did fail right on the welds on the bottom side of anode rode placement hole.
  • Curious, did the tank itself fail ?...would be the only reason to replsce it.
    Just thinking that 10 yrs is a rather short life for a RV water heater.
    My same heater is 15 yrs old.
  • SW6DE..............replace it with another SW6DE as it is a Direct swap
    Trying to replace with a SW10DE would require a larger opening
    Trying to replace with an Atwood Model would require a different size opening and different wiring scheme/controls
Having RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 08, 2025
