ENG2242's avatar
ENG2242
Replacing Water Line Connection (with pics)
If needed replacement: what type water supply line is it {PEX}, and what diameter parts and procedure is required to do so? I realize it has the crimping connection in place. Are there alternatives to this crimp connection? Is there a way to remove the crimp with out the correct removal tool?
(The red line connected to the faucet is the project)
  • Lynnmor wrote:
    I would make the transition from PEX to 3/8" supply lines with a shutoff valve.
    Thank you.
  • I would make the transition from PEX to 3/8" supply lines with a shutoff valve.
  • It's 1/2" PEX and NEVER use a worm drive hose clamp on it. It will pop off.
    Buy a bag of crimp collars and a crimping tool. You'll get plenty of use out of it.
  • wa8yxm's avatar
    wa8yxm
    THat type of crimp removes easily with a dremel.. but be very careful The "Tab" is what I'd cut off then pry it off. Try not to damage the line.
    And when it comes to replacement
    When the shark bites
    into Pex Dear
    Water leaks
    Go away
    into pex dear
    Connections rule the day
    Sharkbite connections are my choce though there is another that works well too
    A plastic thing you can get at a RV store (you might need a tool to slightly flare the pex.
    YOu slip nut over the pex
    Then slightly flare the end
    Slip this plastic thimajig into it till the pex is down past the "Teeth"
    hand tighten the nut (Forces teh teeth to grip the pex
    Very solid
  • disconnect the fitting, (turn off water first), then cut the red hose. Take it to Home Depot or Lowes, and tell them you need to replace it, and use a screw clamp instead of the crimped one. They will know what all you need , and will tell you how to use it.
