- EsacnjExplorerhttps://trakkitgps.com/product/temperature-humidity-sensor/
Anyone know anything about Trakkit THS-WIFI Temperature & Humidity Sensor ? - dieseltruckdrivExplorer III have a three year old model Honeywell that uses two AA batteries and is programmable. If you want to monitor your pets, maybe a webcam you use when you want to instead of a thermostat that will use battery power 24X7.
- ktmrfsExplorer IIx3 on the micro air. does everything we want and then some
- EsacnjExplorerConsidering it for hot weather where you have power and run AC so it could be monitored for pet left in camper should AC fail.
- ThermoguyExplorer IIA device that needs power 24/7 to run WiFi or Bluetooth seems like a bad idea if you plan to be anywhere you don't have a power source. Pulling from your batteries all the time just to have a convenient thermostat might be nice, but would it draw too much power over time?
