Esacnj's avatar
Esacnj
RV 12V Smart WiFi Thermostat
Has anyone had experience or can recommend a manufacturer.
  • I'm using a Micro Air sold by Hutch Mountain. Both Bluetooth & WiFi. Check their website for the correct version for your AC / Furnace.
  • A device that needs power 24/7 to run WiFi or Bluetooth seems like a bad idea if you plan to be anywhere you don't have a power source. Pulling from your batteries all the time just to have a convenient thermostat might be nice, but would it draw too much power over time?
  • Considering it for hot weather where you have power and run AC so it could be monitored for pet left in camper should AC fail.
    I also have a Micro Air Thermostat it has a quirk or 2 but it gets the job done.
  • x3 on the micro air. does everything we want and then some
  • I have a three year old model Honeywell that uses two AA batteries and is programmable. If you want to monitor your pets, maybe a webcam you use when you want to instead of a thermostat that will use battery power 24X7.
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
